02-08-2023
05:38 AM
- Mute
- Permalink
- Report
02-08-2023
05:38 AM
Hi @gustavo.cassel. This most likely will not help this situation any further, but I thought that this would be a good place for such information, just in case. To set the 'defaults' for some of those settings related to performance when opening Inventor documents, there are a few places you can look, and a few settings that may be of interest.
- Application Options > File dab > click the [File Open...] button at the bottom.
- Within that little pop-up dialog, you can set 'default' values for several related settings.
- Application Options > Assembly tab are a couple settings of interest.
- Defer Updates - Nice to have On/checked in some situations, but I usually leave it Off, when not needed
- This setting is within the Document Settings of drawings, instead of in the Application Options
- Express Mode Settings - setting the number lower helps induce Express Mode sooner
- Enable relationship redundancy analysis
- This setting may also cause a bit of slowness sometimes, but I like it On most of the time.
- Application Options > Drawing > Enable background updates - is obviously a 'performance' related setting
- When a Drawing is open/active > Tools tab > Document Settings > Drawing tab > Defer Updates setting
- This could be set in the Template file to perpetuate it into all new documents
- But I generally leave this Off/unchecked most of the time
Wesley Crihfield
(Not an Autodesk Employee)
