srinivas198621
275 Views, 3 Replies
Multiple ipt in one IDW automatic
Hi there!.
I'm using inventor since 2015, for structural steel detailing etc.,
I'm curious to know is there any option / tool to create all .ipt which is created structural steel frame, support etc in one
drawing sheet incl. assembly drawing. ?
eg. i have a one steel frame. that consists of 20 .ipts for instance, i would like to create all of them in one sheet along with their assembly drawing. is there any tool for automatically creating drawings!!! if this can be done in ilogic or something.
Your response would be highly appreciable!!
Srini
Hey @srinivas198621 there can be a lot that goes into drawing automation. Check out the materials from this Autodesk University class for an idea of what you might like & instructions to do so.
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
Hi @tyler.warner
Sorry for the late response..
Thanks for your update!. I'll look into it..
is there any alternative VB code, or add in tool available?.
Best regards,
Srini
If you're looking for a custom solution reach out to these guys: https://draftaid.io/
They did a good job with automating drawings at my last company.
