- Mute
- Permalink
- Report
Hi @gustavo.cassel. Unfortunately, I do not think there is a good answer for that one. Even when opening a file like that manually, and using the Options button in the file explorer dialog to set it to open 'Express' (instead of Full), and checking the checkbox for 'Skip all unresolved files', it still takes a long time just to figure out 'if' there are any 'unresolved' files that it would need to skip. I would assume that something like Vault would help with those types of situations, but I do not have Vault yet, so I could not confirm that.
Edit: I did notice however, that when opening a drawing manually, using Inventor's Open dialog, you can either choose 'Full' and 'Skip all unresolved files' or you can choose 'Defer', but you can not use 'Defer' and 'Skip all unresolved files' together. Maybe that is a hint to how you should set those settings when opening by code using OpenWithOptions.
Wesley Crihfield
(Not an Autodesk Employee)
