- Mute
- Permalink
- Report
Open DrawingDocument with break reference
Hello!!
I'm trying to build a system to open and test some properties and references of drawings in a entire assembly.
What i'm searching for is broken references, wrong properties, missing drawings and so on.
But i'm having an issue when I try to open a drawing that was copied from another and the old one do not exists anymore.
When I open it, Inventor start to search for the reference in the project folder ( which is giant ) and take a lot of time to finally open the file browser.
I've tryied to use the OpenWithOptions method, like below:
NameValueMap map = Global.InventorApplication.TransientObjects.CreateNameValueMap();
map.Add("SkipAllUnresolvedFiles", true);
map.Add("DeferUpdates", false);
DrawingDocument drawingDocument = Global.InventorApplication.Documents.OpenWithOptions("the path here", map, true) as DrawingDocument;
But it not works. The inventor try anyway look the entire project folder and it takes like 2-3 minutes.
I want a way to force open without look for the reference, like in the assemblies when an icon of a folder with a question mark inside.
