Neuzzo
293 Views, 3 Replies
Select case won't update SheetMetal.SetActiveStyle
Hi, on this macro when i change material from material list, it update all my sheet parameter, but not set "SheetMetal.SetActiveStyle". What i'm doing worng?
Dim oDoc As Document
		oDoc = ThisDoc.Document
Dim oSheetMetalComponentDef As Inventor.SheetMetalComponentDefinition
Dim okUnfoldMethod As Inventor.UnfoldMethod
oSheetMetalComponentDef = oDoc.ComponentDefinition
Select Case Materiale
Case iProperties.Material = "811151 AISI 304 sp. 0.8 SB + PVC", iProperties.Material = "811503 AISI 430 sp. 0.8 2B", iProperties.Material = "811531 AISI 430 sp. 0.8 SB + PVC", iProperties.Material = "811535 AISI 430 sp. 0.8 SB + PVC"
		SheetMetal.SetActiveStyle(“8/10 In aria - 304/430”)
		okUnfoldMethod = oSheetMetalComponentDef.UnfoldMethods.Item("8/10 In aria - 304/430")
		oSheetMetalComponentDef.UnfoldMethod = okUnfoldMethod
Case iProperties.Material = "801171 AISI 304 sp.1 2B", iProperties.Material = "811175 AISI 304 sp. 1 SB + PVC", iProperties.Material = "811541 AISI 430 sp. 1 SB + PVC", iProperties.Material = "811547 AISI 430 sp. 1 BA"
		SheetMetal.SetActiveStyle(“10/10 In aria - 304/430”)
		okUnfoldMethod = oSheetMetalComponentDef.UnfoldMethods.Item("10/10 In aria - 304/430")
Case iProperties.Material = "801181 AISI 304 sp. 1.2 2B", iProperties.Material = "811181 AISI 304 sp. 1.2 SB + PVC"
		SheetMetal.SetActiveStyle(“12/10 In aria - 304/430”)
		okUnfoldMethod = oSheetMetalComponentDef.UnfoldMethods.Item("12/10 In aria - 304/430")
Case iProperties.Material = "811191 AISI 304 sp. 1.5 SB + PVC", iProperties.Material = "811505 AISI 430 sp. 1.5 2B", iProperties.Material = "811585 AISI 430 sp. 1.5 BA + PVC"
		SheetMetal.SetActiveStyle(“15/10 In aria - 304/430”)
		okUnfoldMethod = oSheetMetalComponentDef.UnfoldMethods.Item("15/10 In aria - 304/430")
Case iProperties.Material = "801211 AISI 304 sp. 2 2B", iProperties.Material = "811194 AISI 304 sp. 2 SB + PVC", iProperties.Material = "811507 AISI 430 sp. 2 BA"
		SheetMetal.SetActiveStyle(“20/10 In aria - 304/430”)
		okUnfoldMethod = oSheetMetalComponentDef.UnfoldMethods.Item("20/10 In aria - 304/430")
Case iProperties.Material = "811196 AISI 304 sp. 3 SB + PVC", iProperties.Material = "811501 AISI 430 sp. 3 BA"
		SheetMetal.SetActiveStyle(“30/10 In aria - 304/430”)
		okUnfoldMethod = oSheetMetalComponentDef.UnfoldMethods.Item("30/10 In aria - 304/430")
Case iProperties.Material = "811813 ALLUMINATA sp. 0.8"
		SheetMetal.SetActiveStyle(“8/10 In aria - FE/ZN/ALLUMINATA”)
		okUnfoldMethod = oSheetMetalComponentDef.UnfoldMethods.Item("8/10 In aria - FE/ZN/ALLUMINATA")
Case iProperties.Material = "811817 ALLUMINATA sp. 1"
		SheetMetal.SetActiveStyle(“10/10 In aria - FE/ZN/ALLUMINATA”)
		okUnfoldMethod = oSheetMetalComponentDef.UnfoldMethods.Item("10/10 In aria - FE/ZN/ALLUMINATA")
Case iProperties.Material = "811819 ALLUMINATA sp. 1.5"
		SheetMetal.SetActiveStyle(“15/10 In aria - FE/ZN/ALLUMINATA”)
		okUnfoldMethod = oSheetMetalComponentDef.UnfoldMethods.Item("15/10 In aria - FE/ZN/ALLUMINATA")
Case iProperties.Material = "811823 ALLUMINATA sp. 2", iProperties.Material = "811931 Fe sp. 2", iProperties.Material = "811939 FE-ZINCATO sp. 2"
		SheetMetal.SetActiveStyle(“20/10 In aria - FE/ZN/ALLUMINATA”)
		okUnfoldMethod = oSheetMetalComponentDef.UnfoldMethods.Item("20/10 In aria - FE/ZN/ALLUMINATA")
Case iProperties.Material = "811937 Fe sp. 3", iProperties.Material = "811941 FE-ZINCATO sp. 3"
		SheetMetal.SetActiveStyle(“30/10 In aria - FE/ZN/ALLUMINATA”)
		okUnfoldMethod = oSheetMetalComponentDef.UnfoldMethods.Item("30/10 In aria - FE/ZN/ALLUMINATA")
End Select
Danilo "DannyGi" G.
Mechanical design engineer and product developer
