Neuzzo
293 Views, 3 Replies
Select case won't update SheetMetal.SetActiveStyle
Hi, on this macro when i change material from material list, it update all my sheet parameter, but not set "SheetMetal.SetActiveStyle". What i'm doing worng?
Dim oDoc As Document
		oDoc = ThisDoc.Document
Dim oSheetMetalComponentDef As Inventor.SheetMetalComponentDefinition
Dim okUnfoldMethod As Inventor.UnfoldMethod
oSheetMetalComponentDef = oDoc.ComponentDefinition
Select Case Materiale
Case iProperties.Material = "811151 AISI 304 sp. 0.8 SB + PVC", iProperties.Material = "811503 AISI 430 sp. 0.8 2B", iProperties.Material = "811531 AISI 430 sp. 0.8 SB + PVC", iProperties.Material = "811535 AISI 430 sp. 0.8 SB + PVC"
		SheetMetal.SetActiveStyle(“8/10 In aria - 304/430”)
		okUnfoldMethod = oSheetMetalComponentDef.UnfoldMethods.Item("8/10 In aria - 304/430")
		oSheetMetalComponentDef.UnfoldMethod = okUnfoldMethod
Case iProperties.Material = "801171 AISI 304 sp.1 2B", iProperties.Material = "811175 AISI 304 sp. 1 SB + PVC", iProperties.Material = "811541 AISI 430 sp. 1 SB + PVC", iProperties.Material = "811547 AISI 430 sp. 1 BA"
		SheetMetal.SetActiveStyle(“10/10 In aria - 304/430”)
		okUnfoldMethod = oSheetMetalComponentDef.UnfoldMethods.Item("10/10 In aria - 304/430")
Case iProperties.Material = "801181 AISI 304 sp. 1.2 2B", iProperties.Material = "811181 AISI 304 sp. 1.2 SB + PVC"
		SheetMetal.SetActiveStyle(“12/10 In aria - 304/430”)
		okUnfoldMethod = oSheetMetalComponentDef.UnfoldMethods.Item("12/10 In aria - 304/430")
Case iProperties.Material = "811191 AISI 304 sp. 1.5 SB + PVC", iProperties.Material = "811505 AISI 430 sp. 1.5 2B", iProperties.Material = "811585 AISI 430 sp. 1.5 BA + PVC"
		SheetMetal.SetActiveStyle(“15/10 In aria - 304/430”)
		okUnfoldMethod = oSheetMetalComponentDef.UnfoldMethods.Item("15/10 In aria - 304/430")
Case iProperties.Material = "801211 AISI 304 sp. 2 2B", iProperties.Material = "811194 AISI 304 sp. 2 SB + PVC", iProperties.Material = "811507 AISI 430 sp. 2 BA"
		SheetMetal.SetActiveStyle(“20/10 In aria - 304/430”)
		okUnfoldMethod = oSheetMetalComponentDef.UnfoldMethods.Item("20/10 In aria - 304/430")
Case iProperties.Material = "811196 AISI 304 sp. 3 SB + PVC", iProperties.Material = "811501 AISI 430 sp. 3 BA"
		SheetMetal.SetActiveStyle(“30/10 In aria - 304/430”)
		okUnfoldMethod = oSheetMetalComponentDef.UnfoldMethods.Item("30/10 In aria - 304/430")
Case iProperties.Material = "811813 ALLUMINATA sp. 0.8"
		SheetMetal.SetActiveStyle(“8/10 In aria - FE/ZN/ALLUMINATA”)
		okUnfoldMethod = oSheetMetalComponentDef.UnfoldMethods.Item("8/10 In aria - FE/ZN/ALLUMINATA")
Case iProperties.Material = "811817 ALLUMINATA sp. 1"
		SheetMetal.SetActiveStyle(“10/10 In aria - FE/ZN/ALLUMINATA”)
		okUnfoldMethod = oSheetMetalComponentDef.UnfoldMethods.Item("10/10 In aria - FE/ZN/ALLUMINATA")
Case iProperties.Material = "811819 ALLUMINATA sp. 1.5"
		SheetMetal.SetActiveStyle(“15/10 In aria - FE/ZN/ALLUMINATA”)
		okUnfoldMethod = oSheetMetalComponentDef.UnfoldMethods.Item("15/10 In aria - FE/ZN/ALLUMINATA")
Case iProperties.Material = "811823 ALLUMINATA sp. 2", iProperties.Material = "811931 Fe sp. 2", iProperties.Material = "811939 FE-ZINCATO sp. 2"
		SheetMetal.SetActiveStyle(“20/10 In aria - FE/ZN/ALLUMINATA”)
		okUnfoldMethod = oSheetMetalComponentDef.UnfoldMethods.Item("20/10 In aria - FE/ZN/ALLUMINATA")
Case iProperties.Material = "811937 Fe sp. 3", iProperties.Material = "811941 FE-ZINCATO sp. 3"
		SheetMetal.SetActiveStyle(“30/10 In aria - FE/ZN/ALLUMINATA”)
		okUnfoldMethod = oSheetMetalComponentDef.UnfoldMethods.Item("30/10 In aria - FE/ZN/ALLUMINATA")
End Select
Danilo "DannyGi" G.
Mechanical design engineer and product developer
Cadkunde.nl
in reply to: Neuzzo
Dim oDoc As PartDocument = ThisDoc.Document
If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
Dim oSheetMetalComponentDef As Inventor.SheetMetalComponentDefinition = oDoc.ComponentDefinition
oSheetMetalComponentDef.SheetMetalStyles.Item("Default").Activate
End If
First, oDoc as Document won't work, there is no componentdefinition within it. use PartDocument
Then check if it is a sheetmetal doc with subtype to prevent errors.
I can't see 'Sheetmetal' declared in your script and with object model i couldnt find 'setactivestyle' anywhere.
Neuzzo
in reply to: Cadkunde.nl
I've modify with your suggest, all work but sheetmetalstyles no.
		oSheetMetalComponentDef.SheetMetalStyles.Item("8/10 In aria - 304/430").Activate
		oSheetMetalComponentDef.SheetMetalStyles.Item("10/10 In aria - 304/430").Activate
		oSheetMetalComponentDef.SheetMetalStyles.Item("12/10 In aria - 304/430").Activate
		oSheetMetalComponentDef.SheetMetalStyles.Item("15/10 In aria - 304/430").Activate
		oSheetMetalComponentDef.SheetMetalStyles.Item("20/10 In aria - 304/430").Activate
		oSheetMetalComponentDef.SheetMetalStyles.Item("30/10 In aria - 304/430").Activate
		oSheetMetalComponentDef.SheetMetalStyles.Item("8/10 In aria - FE/ZN/ALLUMINATA").Activate
		oSheetMetalComponentDef.SheetMetalStyles.Item("10/10 In aria - FE/ZN/ALLUMINATA").Activate
		oSheetMetalComponentDef.SheetMetalStyles.Item("15/10 In aria - FE/ZN/ALLUMINATA").Activate
		oSheetMetalComponentDef.SheetMetalStyles.Item("20/10 In aria - FE/ZN/ALLUMINATA").Activate
		oSheetMetalComponentDef.SheetMetalStyles.Item("30/10 In aria - FE/ZN/ALLUMINATA").Activate
End Select
eND iF
This is the old one that work like a charm:
If iProperties.Material = "801171 AISI 304 sp.1 2B"
	Else If iProperties.Material = "801181 AISI 304 sp. 1.2 2B"
	Else If iProperties.Material = "801211 AISI 304 sp. 2 2B"
	Else If iProperties.Material = "811151 AISI 304 sp. 0.8 SB + PVC"
	Else If iProperties.Material = "811175 AISI 304 sp. 1 SB + PVC"
	Else If iProperties.Material = "811181 AISI 304 sp. 1.2 SB + PVC"
	Else If iProperties.Material = "811191 AISI 304 sp. 1.5 SB + PVC"
	Else If iProperties.Material = "811194 AISI 304 sp. 2 SB + PVC"
	Else If iProperties.Material = "811196 AISI 304 sp. 3 SB + PVC"
	Else If iProperties.Material = "811501 AISI 430 sp. 3 BA"
	Else If iProperties.Material = "811525 AISI 430 sp. 0.8 BA"
	Else If iProperties.Material = "811531 AISI 430 sp. 0.8 SB + PVC"
	Else If iProperties.Material = "811535 AISI 430 sp. 0.8 SB + PVC"
		okUnfoldMethod = oSheetMetalComponentDef.UnfoldMethods.Item("18/10 In aria - 304/430")
	Else If iProperties.Material = "811541 AISI 430 sp. 1 SB + PVC"
	Else If iProperties.Material = "811547 AISI 430 sp. 1 BA"
	Else If iProperties.Material = "811505 AISI 430 sp. 1.5 2B"
	Else If iProperties.Material = "811585 AISI 430 sp. 1.5 BA + PVC"
	Else If iProperties.Material = "811587 AISI 430 sp. 2 BA"
	Else If iProperties.Material = "811813 ALLUMINATA sp. 0.8"
	Else If iProperties.Material = "811817 ALLUMINATA sp. 1"
	Else If iProperties.Material = "811819 ALLUMINATA sp. 1.5"
	Else If iProperties.Material = "811823 ALLUMINATA sp. 2"
	Else If iProperties.Material = "811931 Fe sp. 2"
	Else If iProperties.Material = "811937 Fe sp. 3"
	Else If iProperties.Material = "811939 FE-ZINCATO sp. 2"
	Else If iProperties.Material = "811941 FE-ZINCATO sp. 3"
End If
In the old one, i haven't declare SheetMetal.SetActiveStyle, but it work.
Danilo "DannyGi" G.
Neuzzo
in reply to: Neuzzo
My mistake. The error is in "Case" declaration.
This is the correct one if someone need it:
Select Case iProperties.Material
Case "811151 AISI 304 sp. 0.8 SB + PVC", "811503 AISI 430 sp. 0.8 2B", "811531 AISI 430 sp. 0.8 SB + PVC", "811535 AISI 430 sp. 0.8 SB + PVC"
Case "801171 AISI 304 sp.1 2B", "811175 AISI 304 sp. 1 SB + PVC", "811541 AISI 430 sp. 1 SB + PVC", "811547 AISI 430 sp. 1 BA"
Case "801181 AISI 304 sp. 1.2 2B", "811181 AISI 304 sp. 1.2 SB + PVC"
Case "811191 AISI 304 sp. 1.5 SB + PVC", "811505 AISI 430 sp. 1.5 2B", "811585 AISI 430 sp. 1.5 BA + PVC"
Case "801211 AISI 304 sp. 2 2B", "811194 AISI 304 sp. 2 SB + PVC", "811507 AISI 430 sp. 2 BA"
Case "811196 AISI 304 sp. 3 SB + PVC", "811501 AISI 430 sp. 3 BA"
Case "811813 ALLUMINATA sp. 0.8"
Case "811817 ALLUMINATA sp. 1"
Case "811819 ALLUMINATA sp. 1.5"
Case "811823 ALLUMINATA sp. 2", "811931 Fe sp. 2", "811939 FE-ZINCATO sp. 2"
Case "811937 Fe sp. 3", "811941 FE-ZINCATO sp. 3"
End Select
Danilo "DannyGi" G.
