01-31-2023
05:36 AM
- Mute
- Permalink
- Report
01-31-2023
05:36 AM
Hi @alan.wedge. Can you please inform us of which iProperty you want to use the value of for the PDF's file name? If this drawing has more than one sheet, then do you want all of its sheets to be exported as a single, multi-page PDF document, or do you need each sheet to be a separate PDF document? If you were to export the drawing as a PDF manually, how would you set each option? For example: Just current sheet or All Sheets or Sheets in specific range? All colors as Black or not? Remove object line weights or not? Vector resolution: set values ranging from 150 DPI to 4800 DPI? Display published file in viewer or not?
Wesley Crihfield
(Not an Autodesk Employee)
