01-25-2023
03:01 PM
- Mute
- Permalink
- Report
01-25-2023
03:01 PM
@tmathieson - Hi. Here's an attempt with VBA at creating a workpoint(s) in an assembly that locates the intersection of two planes and a curved surface. You can determine the line of intersection from the two chosen planes by computing the cross product of their normal vectors. From there, you can use the intersecting line's ".IntersectWithSurface()" method to create a collection of viable points. A further check then determines if the point is actually on the chosen cylindrical face.
Sub Main()
Dim inv As Inventor.Application
Set inv = ThisApplication
Dim tg As Inventor.TransientGeometry
Set tg = inv.TransientGeometry
Dim asmdoc As Inventor.AssemblyDocument
Set asmdoc = inv.ActiveDocument
Dim planeOne As Inventor.WorkPlane
Dim planeTwo As Inventor.WorkPlane
'Set planeOne = asmdoc.ComponentDefinition.WorkPlanes.Item(1)
'Set planeTwo = asmdoc.ComponentDefinition.WorkPlanes.Item(2)
Set planeOne = inv.CommandManager.Pick(kWorkPlaneFilter, "pick first plane")
Set planeTwo = inv.CommandManager.Pick(kWorkPlaneFilter, "pick second plane")
Dim uvPlaneOneNormal As Inventor.UnitVector
Dim uvPlaneTwoNormal As Inventor.UnitVector
Set uvPlaneOneNormal = planeOne.Plane.Normal
Set uvPlaneTwoNormal = planeTwo.Plane.Normal
Dim cp As Variant
cp = CrossProduct( _
v1:=Array(uvPlaneOneNormal.X, uvPlaneOneNormal.Y, uvPlaneOneNormal.Z), _
v2:=Array(uvPlaneTwoNormal.X, uvPlaneTwoNormal.Y, uvPlaneTwoNormal.Z))
'Debug.Print ("a(x-x0) + b(y-y0) + c(z+z0) = 0")
'Debug.Print (uvPlaneOneNormal.X & "(x-" & planeOne.Plane.RootPoint.X & ") + " & uvPlaneOneNormal.Y & "(y-" & planeOne.Plane.RootPoint.Y & ") + " & uvPlaneOneNormal.Z & "(z-" & planeOne.Plane.RootPoint.Z & ")")
'Debug.Print (uvPlaneTwoNormal.X & "(x-" & planeTwo.Plane.RootPoint.X & ") + " & uvPlaneTwoNormal.Y & "(y-" & planeTwo.Plane.RootPoint.Y & ") + " & uvPlaneTwoNormal.Z & "(z-" & planeTwo.Plane.RootPoint.Z & ")")
Dim wa As Inventor.WorkAxis
Set wa = asmdoc.ComponentDefinition.WorkAxes.AddFixed( _
Point:=planeOne.Plane.RootPoint, _
Axis:=inv.TransientGeometry.CreateUnitVector(cp(0), cp(1), cp(2)))
Dim surfCurve As Inventor.Face
Set surfCurve = inv.CommandManager.Pick(kPartFaceCylindricalFilter, "pick a cylindrical face")
Dim pColl As Inventor.ObjectsEnumerator
Set pColl = wa.Line.IntersectWithSurface(surfCurve.Geometry)
Dim foundPoint As Boolean
foundPoint = False
If Not pColl Is Nothing Then
For Each Point In pColl
If surfCurve.GetClosestPointTo(Point).IsEqualTo(Point) Then
asmdoc.ComponentDefinition.WorkPoints.AddFixed (Point)
If foundPoint = False Then
foundPoint = True
End If
End If
Next
End If
Call MsgBox("No intersection points found. :(")
End If
End Sub
Function CrossProduct(v1 As Variant, v2 As Variant) As Variant
CrossProduct = Array( _
v1(1) * v2(2) - v1(2) * v2(1), _
v1(2) * v2(0) - v1(0) * v2(2), _
v1(0) * v2(1) - v1(1) * v2(0))
End Function
