Darkforce_the_ilogic_guy
150 Views, 1 Reply
how will the vb code look like if I wanted til use before save trigger in an exe program ?
I would like to create a program that run some ilogic code by start an exe file...that run. while I use inventor
I dont want to use that inventor build in version.  because I wanted to a more complex control of with ilogic that might be run. Maybe as a group of users or as each user level... or maybe multi profile that the users can easily change betwine.
but to start with I just need to know how to use the trigger form the exe program
You can use handlers to let your code respond to events in Inventor.
I use this for application events in my visual studio project:
Public Class ApplicationEvents
Implements Inventor.ApplicationAddInServer
Private AppEvents As Inventor.ApplicationEvents
Public InventorApp As Inventor.Application
Public Sub Activate(siteObj As Inventor.ApplicationAddInSite, loaded1stTime As Boolean) Implements ApplicationAddInServer.Activate
InventorApp = siteObj.Application
AppEvents = InventorApp.ApplicationEvents
AddHandler AppEvents.OnActivateDocument, AddressOf oAppEvents_OnActivateDocument
End Sub
Private Sub oAppEvents_OnActivateDocument(ByVal DocumentObject As Inventor._Document, ByVal BeforeOrAfter As Inventor.EventTimingEnum, ByVal Context As Inventor.NameValueMap, ByRef HandlingCode As Inventor.HandlingCodeEnum) 'Handles oAppEvents.OnActivateDocument
If BeforeOrAfter = EventTimingEnum.kBefore Then
'your code here
End If
End Sub
Public Sub Deactivate() Implements ApplicationAddInServer.Deactivate
If InventorApp IsNot Nothing Then
Marshal.FinalReleaseComObject(InventorApp)
End If
End Sub
