- Mute
- Permalink
- Report
Hi @ober2558. If you see the a tab beside your "Model" tab that is labeled "Forms", click on that tab so that you can see its contents. If you do not see it, then go to your View tab (on the main top ribbon), then click on User Interface tool, then make sure you check the checkbox beside 'iLogic', 'iLogic Log'. This tab will usually be empty in a 'New' document, because this is where local forms are kept (forms that are saved within that document only). You will want to create a new Form there, by right-clicking somewhere in the open area of the main part of that tab (not on the name of the tab), and choose 'Add Form'. While that dialog is open, select 'iProperties' (near upper left of dialog), which will show a list of available iProperties you can choose from. Now drag & drop any of those properties over into the upper right area of the dialog, and that will create line items for those iProperties, and they will show up in the main form. When you click OK on that dialog, anything you put into that upper right area will now be shown in the form as interactive controls for you to view or edit those values. Not all iProperties can be changed. Some are 'ReadOnly'. Once you have the form looking the way you want, then we can move on to creating an iLogic rule that will cause this form to show when you create a new drawing.
Wesley Crihfield
(Not an Autodesk Employee)
