ober2558
335 Views, 2 Replies
Prompt to fill out property fields/field text for the title block in inventor drawing
I am looking for a way to use iLogic so that when a drawing is created a prompt is pulled up for the user to populate the property fields located in the title block if they are not already filled out. Please provide any information or suggestions you can. I am not very skilled with iLogic so detailed descriptions and code examples are much appreciated. Thank you!
