op_thorsager
in reply to: A.Acheson
Hi, sorry for the late response - i've been caught up in learning iLogic, as i find it very fun to write.
The frustration i get from a non functioning code just gives me more drive to solve it, so i end up hyperfocusing on it and forget everything else around me, so i just now remembered that i made this post.
I ended up going away from the embedding/replace embedded file method and decided using goexcel. I've created a standard sheet layout which is locked, so the people using my tool wont be able to mess up the cells, then i set iLogic to read from the driving sheet cells. which reference a userfriendly sheet within the same excel file.
solved my issue by using the following code:
'Declare Iventor File Dialog
Dim oFileDlg As Inventor.FileDialog
Dim oDocFile As Document, oDocFileName As String
'Run File Selection Code
InventorVb.Application.CreateFileDialog(oFileDlg)
'Allow Selection Of Excel Files
oFileDlg.Filter = "Excel Spec Sheet (*.xls;*.xlsx;*xlsm)|*.xls;*.xlsx;*xlsm"
'Get File Path, setting the initial path to the same folder that the model is saved In.
oFileDlg.InitialDirectory = ThisDoc.Path
oFileDlg.CancelError = True
On Error Resume Next
'Show Open File Dialog Window.
oFileDlg.ShowOpen()
If oFileDlg.FileName = ""
	MessageBox.Show("No File Selected", "Error")
GoTo LAUNCH_FORM
End If
'declares selected file name
Dim xSpec As String = oFileDlg.FileName
'Set Filename parameter to the path.
	Parameter("Filename") = xSpec
	Parameter("Veneer:1", "VeneerDepth") = VeneerDepthBuild
	Parameter("Veneer:1", "VeneerWidth") = VeneerWidthBuild
	Parameter("Veneer:1", "VeneerHeight") = VeneerHeightBuild
	Parameter("CrossBar:1", "CrossH") = CrossHeightBuild
	Parameter("CrossBar:1", "CrossD") = CrossDepthBuild
	Parameter("CrossBar:1", "CrossW") = CrossWidthBuild
	Parameter("CrossBar:2", "CrossH") = CrossHeightBuild
	Parameter("CrossBar:2", "CrossD") = CrossDepthBuild
	Parameter("CrossBar:2", "CrossW") = CrossWidthBuild
	Parameter("CrossOffBot") = CrossOffBuild
	Parameter("CtopOffset") = CtopOffsetBuild
	GoExcel.Open(xSpec, "Driver")
VeneerHeightBuild = GoExcel.CellValue(xSpec, "Driver", "B7")
VeneerDepthBuild = GoExcel.CellValue(xSpec, "Driver", "C7")
VeneerWidthBuild = GoExcel.CellValue(xSpec, "Driver", "D7")
CrossHeightBuild = GoExcel.CellValue(xSpec, "Driver", "B6")
CrossDepthBuild = GoExcel.CellValue(xSpec, "Driver", "C6")
CrossWidthBuild = GoExcel.CellValue(xSpec, "Driver", "H12")
CrossOffBuild = GoExcel.CellValue(xSpec, "Driver", "H7")
CtopOffsetBuild = GoExcel.CellValue(xSpec, "Driver", "H8")
FirstVeneerOffset = GoExcel.CellValue(xSpec, "Driver", "-H6")
ModuleDim = GoExcel.CellValue(xSpec, "Driver", "D6")
	GoExcel.close
'ask if user wants to update dialog
question = MessageBox.Show("Update model To spec sheet?", "xxx Gen v.3", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
	If question = vbYes Then
		Parameter.UpdateAfterChange = True
		iLogicVb.UpdateWhenDone = True
		Parameter("CrossOffBot") = -CrossOffBuild
	Else If question = vbNo Then
		Parameter.UpdateAfterChange = False
		iLogicVb.UpdateWhenDone = False
		Parameter("Veneer:1", "VeneerDepth") = DefaultVD
		Parameter("Veneer:1", "VeneerWidth") = DefaultVW
		Parameter("Veneer:1", "VeneerHeight") = DefaultVH
		Parameter("CrossBar:1", "CrossH") = DefaultCH
		Parameter("CrossBar:1", "CrossD") = DefaultCD
		Parameter("CrossBar:1", "CrossW") = DefaultCW
		Parameter("CrossBar:2", "CrossH") = DefaultCH
		Parameter("CrossBar:2", "CrossD") = DefaultCD
		Parameter("CrossBar:2", "CrossW") = DefaultCW
	End If
LAUNCH_FORM:
iLogicForm.Show("xxx Product Generator")
