01-14-2023
05:14 AM
- Mute
- Permalink
- Report
01-14-2023
05:14 AM
A rule for adding and removing a solid body using a bounded pitch and length dimension.
Hello.I would need a rule for this problem.
1. Add or remove the "crossbar" body when changing the length so that the "control dimension" is in the range of 80-90mm.
If it doesn't work, get as close as possible to these dimensions.
2. At the same time mark the newly created "crossbar" so that they are also in "Rectangular pattern_B".
