salih_kapucu
324 Views, 3 Replies
Order of Operations (Assembly)
After the measurements are set with ilogic, I want the assembly process to be performed. Is this possible?
Note: Assemblies were not made with ilogic.
A.Acheson
in reply to: salih_kapucu
Hi @salih_kapucu
Could you provide more information of what you mean by measurement and assembly process? Some images/ video of what your doing manually would help. Do you have a ilogic/vba rule  you have started that you can also post?
Regards
Alan
salih_kapucu
in reply to: A.Acheson
Parts created with ilogic variables were assembled manually. The lengths of the parts change with the data transmitted from the main assembly. I want to prevent the parts from seeing the mate and making an error after their size changes.
A.Acheson
It looks like your dragging the part in the video? Is that correct? Without the code and a sample of the model your using it is very difficult to see how to help. It may be the case that you need to suppress the mates and unsuppress after the diameter is changed.
Regards
Alan
