A.Acheson
in reply to: op_thorsager
There is likely no need to import/ embed the excel sheet. Based on your previous method to import the iproperties from the excel file using go excel. As long as the excel file is located in the same folder as the inventor document and you have defined the name of the file then go excel function will find the excel file.
Filename only
GoExcel.Open("dwg-param.xlsx", "Sheet2")
Another method is to use the Path function of the document your running the rule on to give the directory The file is stored in.
GoExcel.Open(ThisDoc.Path & "\dwg-param.xlsx", "Sheet2")
Regards
Alan
