01-05-2023
10:35 AM
- Mute
- Permalink
- Report
01-05-2023
10:35 AM
Hi Maxim,
I agree it is a problem. The API sees the original names, but the browser shows the names based on the current language. Note that this only happens for default (system-generated) names. If you rename the solids, then the new names will show the same in all languages.
You said "define particular solid body (SurfaceBody) using its English name". I think you mean "access" or "find" instead of "define", right? You're trying to find a body by name?
The workaround would be: instead of using the names from the browser, list out the names using the API. Then use those names in your code.
Mike Deck
Software Developer
Autodesk, Inc.
