@shubham.pawar.external
I tried with this code and it is adding bearing with the name only, can you try the same and then modify this as per your requirement?
Components.AddContentCenterPart("bearing-01","Shaft Parts:Bearings:Roller Bearings:Spherical Roller Bearings","DIN 635 SKF- with Cylindrical Bore","SKF (22322 CC/W33)", DIN_635_SKF_with_CylPos)
If you want to add with size, make sure you write correct column names and family names as well. See below snip where I am adding Row no 6. SKF (22206 CC) with Inside and Outside diameter written in the code snippet.
Components.AddContentCenterPart("bearing-01","Shaft Parts:Bearings:Roller Bearings:Spherical Roller Bearings","DIN 635 SKF- with Cylindrical Bore",{"Size Designation","SKF (22206 CC)","Inside Diameter","30","Outside Diameter","62"},position := Nothing)
Hope this will be helpful.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
