12-21-2022
12:09 AM
- Mute
- Permalink
- Report
12-21-2022
12:09 AM
Use this:
Dim AssemblyDOC As AssemblyDocument = ThisApplication.ActiveDocument
Dim ITEM As Inventor.ComponentOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select an Item")
If (Not ITEM Is Nothing) Then
Dim ITEMPropertySets As PropertySets = ITEM.Definition.Document.PropertySets
Dim ITEMPropertySet As PropertySet = ITEMPropertySets.Item("Design Tracking Properties")
Dim ITEMMaterial As Inventor.Property = ITEMPropertySet.Item("Material")
MsgBox("THE PART NUMBER: " & ITEMMaterial.Value)
End If
Arthur Knoors
Arthur Knoors
Autodesk Affiliations:
