12-20-2022
04:13 AM
- Mute
- Permalink
- Report
12-20-2022
04:13 AM
Or more options like this:
Dim AssemblyDOC As AssemblyDocument = ThisApplication.ActiveDocument
Dim ITEM As Inventor.ComponentOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select an Item")
If (Not ITEM Is Nothing) Then
Dim a As Inventor.Document = ITEM.Definition.Document
Dim MyMass As String= a.ComponentDefinition.MassProperties.Mass
Dim MyVolume As String = a.ComponentDefinition.MassProperties.Volume
Dim MyArea As String = a.ComponentDefinition.MassProperties.Area
MsgBox("THE MASS: " & MyMass)
MsgBox("THE VOLUME: " & MyVolume)
MsgBox("THE AREA: " & MyArea)
End If
Best regards,
Arthur Knoors
Arthur Knoors
Autodesk Affiliations:
