12-20-2022
04:07 AM
- Mute
- Permalink
- Report
12-20-2022
04:07 AM
Dim AssemblyDOC As AssemblyDocument = ThisApplication.ActiveDocument
Dim ITEM As Inventor.ComponentOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select an Item")
If (Not ITEM Is Nothing) Then
Dim a As Inventor.Document = ITEM.Definition.Document
MsgBox("THE MASS IS: " & a.ComponentDefinition.MassProperties.Mass)
End If
Arthur Knoors
Autodesk Affiliations:
