12-20-2022
02:47 AM
- Mute
- Permalink
- Report
12-20-2022
02:47 AM
Here we go, I managed to convert the iLogic code to it's corresponding API version.
Option Explicit
Sub PartSelection()
'Select drawing curve of the part
Dim oPick As DrawingCurveSegment
Set oPick = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Pick drawing curve")
'Get assembly occurrene which the selected DrawingCurveSegment belongs to
Dim curveSegment As DrawingCurveSegment
Set curveSegment = oPick
Dim parentCurve As DrawingCurve
Set parentCurve = curveSegment.Parent
Dim someProxy As EdgeProxy 'changed
Set someProxy = parentCurve.ModelGeometry
Dim partOcc As ComponentOccurrence
Set partOcc = someProxy.ContainingOccurrence
'Get AssemblyDocument referenced by DrawingView
Dim dView As drawingView 'needs to be checked
Set dView = parentCurve.Parent
Dim viewAsm As AssemblyDocument
Set viewAsm = dView.ReferencedDocumentDescriptor.ReferencedDocument
'Get all occurrences which has the same ComponentDefinition
Dim allInstancesOfPartOcc As ComponentOccurrencesEnumerator
Set allInstancesOfPartOcc = viewAsm.ComponentDefinition.Occurrences.AllLeafOccurrences(partOcc.Definition)
'Get all DrawingCurveSegments of each part instance
'and convert them to ObjectCollection
Dim occDrawingCurvesCollection As ObjectCollection
Set occDrawingCurvesCollection = ThisApplication.TransientObjects.CreateObjectCollection()
Dim occ As ComponentOccurrence
For Each occ In allInstancesOfPartOcc
Dim occDrawingCurves As DrawingCurvesEnumerator
Set occDrawingCurves = dView.DrawingCurves(occ)
Dim occDrawingCurve As DrawingCurve
For Each occDrawingCurve In occDrawingCurves
Dim occDrawingCurveSegment As DrawingCurveSegment
For Each occDrawingCurveSegment In occDrawingCurve.Segments
Call occDrawingCurvesCollection.Add(occDrawingCurveSegment)
Next
Next
Next
'Do something useful with occDrawingCurvesCollection
'Select all DrawingCurveSegments of the occ in the DrawingView
Dim drawingDoc As DrawingDocument
Set drawingDoc = dView.Parent.Parent
Call drawingDoc.SelectSet.SelectMultiple(occDrawingCurvesCollection)
End Sub
