Dim AssemblyDOC As AssemblyDocument = ThisApplication.ActiveDocument
Dim ITEM As Inventor.ComponentOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select an Item")
If (Not ITEM Is Nothing) Then
	Dim ITEMPropertySets As PropertySets = ITEM.Definition.Document.PropertySets
	Dim ITEMPropertySet As PropertySet = ITEMPropertySets.Item("Design Tracking Properties")
	Dim ITEMPartNumber As Inventor.Property = ITEMPropertySet.Item("Part Number")
	MsgBox("THE PART NUMBER: " & ITEMPartNumber.Value)
End If
Arthur Knoors
Autodesk Affiliations:
