- Mute
- Permalink
- Report
Dears,
Could you please help me check what's wrong in my Code that I'm using to read selection item's iProperties:
Dim AssemblyDOC As AssemblyDocument = _InventorApp.ActiveDocument
Dim ITEM = _InventorApp.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select an Item")
If (Not ITEM Is Nothing) Then
Dim ITEMPropertySets As PropertySets = ITEM.PropertySets
Dim ITEMPropertySet As PropertySet = nITEMPropertySets.Item("Design Tracking Properties")
Dim ITEMPartNumber As Property = nITEMPropertySet.Item("Part Number")
MsgBox("THE PART NUMBER: " & ITEMPartNumber)
End IfI'm using VS2022 + Inventor 2018
Thank you very much!
- Mute
- Permalink
- Report
Hi @ngnam1988. The object you are most likely returning from your Pick method is a ComponentOccurrence, not a Document object. The ComponentOccurrence object does not directly have a 'PropertySets' property, that is only accessible from a Document type object. There are a few ways to access the iProperties that are associated with an assembly component, but none of them are direct, the way you have it there. If going the API way, similar to what you have above, then you will need to get the Document that the assembly component represents first, then you can use that Document to access the iProperties from. There are two ways to get the Document from a component:
- ComponentOccurrence.ReferencedDocumentDescriptor.ReferencedDocument
- ComponentOccurrence.Definition.Document
Or, if the component is a 'top level' one (not within a sub assembly), you may be able to use the iLogic shortcut snippet iProperties.Value(ComponentOccurrence.Name, "PropertySetName", "Property.Name") to access it.
Edit: Below is an example of one way to alter your code.
Dim oComp As ComponentOccurrence = ITEM 'or try to Cast it to correct Type
Dim oCompDoc As Document = oComp.ReferencedDocumentDescriptor.ReferencedDocument
Dim ITEMPropertySets As PropertySets = oCompDoc.PropertySets
Dim ITEMPropertySet As PropertySet = ITEMPropertySets.Item("Design Tracking Properties")
Dim ITEMPartNumber As Inventor.Property = ITEMPropertySet.Item("Part Number")
End If
Wesley Crihfield
(Not an Autodesk Employee)
- Mute
- Permalink
- Report
Dim AssemblyDOC As AssemblyDocument = ThisApplication.ActiveDocument
Dim ITEM As Inventor.ComponentOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select an Item")
Dim ITEMPropertySets As PropertySets = ITEM.Definition.Document.PropertySets
MsgBox("THE PART NUMBER: " & ITEMPartNumber.Value)
End If
Arthur Knoors
Autodesk Affiliations:
- Mute
- Permalink
- Report
It's very useful for me who starting to learn with code.
- Mute
- Permalink
- Report
Dear @WCrihfield , @bradeneuropeArthur
By this way can we get the physical properties (Mass, Volume, ...) selected item? Could you help me how to do it?
- Mute
- Permalink
- Report
Dim a As Inventor.Document = ITEM.Definition.Document
MsgBox("THE MASS IS: " & a.ComponentDefinition.MassProperties.Mass)
End If
Arthur Knoors
- Mute
- Permalink
- Report
Or more options like this:
Dim MyMass As String= a.ComponentDefinition.MassProperties.Mass
Dim MyVolume As String = a.ComponentDefinition.MassProperties.Volume
Dim MyArea As String = a.ComponentDefinition.MassProperties.Area
MsgBox("THE MASS: " & MyMass)
MsgBox("THE VOLUME: " & MyVolume)
MsgBox("THE AREA: " & MyArea)
End If
Best regards,
Arthur Knoors
Arthur Knoors
- Mute
- Permalink
- Report
Thank you very much! @bradeneuropeArthur
I learnt to much from your codes. I'm trying get Material of selected item. Could you please help me?
- Mute
- Permalink
- Report
Use this:
Dim ITEMMaterial As Inventor.Property = ITEMPropertySet.Item("Material")
MsgBox("THE PART NUMBER: " & ITEMMaterial.Value)
End If
Arthur Knoors
Arthur Knoors
- Mute
- Permalink
- Report
Thanks for your help @WCrihfield @bradeneuropeArthur
I got it, and I can understand the key for my question is:
Dim ITEM As Inventor.Document = ITEM.Definition.Document
- Mute
- Permalink
- Report
Please read this overview of properties:
Arthur Knoors
