insomnix
in reply to: insomnix
OK, forward movement. I found the line I need to change the model state in the view. Still some work to do here. There were some odd results with the part number field in the title block, like it wasn't updating with the model state change. I may just need to add a line to save before I print. Will try to work that out tomorrow unless someone has a suggestion.  Until then, the update I made to the generate rule is below.
	oDoc = ThisApplication.Documents.Open(dwgFile)
	Dim View As DrawingView
	For Each sheet As Sheet In oDoc.Sheets
		Sheet.Activate
		Try
			If Sheet.DrawingViews.Count > 0 Then
		        For Each View In Sheet.DrawingViews
					If View.Name = "FRONT" Then
						View.SetActiveModelState(model_state_fin)
					End If
		        Next
		    End If
		Catch
		End Try
	Next
