Hi @anuj16797
I don't know of a way to do this with built in Inventor settings, but I suppose you could create some custom code for this.
Here is a past post concerning creating a custom iProeprty to handle a format change for the mass.
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/custom-properties/m-p/4808383#M48457
The syntax to add the thousands separator would be something like this:
Dim oValue As Double = 88888888888888
If oValue > 999 Then
	oMsg = oValue.ToString("###,###")
End If
MsgBox(oMsg)
If you have questions about how to implement this via code, I would suggest creating a new post on the customization forum and asking those questions,  and linking back to this topic for reference.
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/bd-p/120
I hope this helps.
Curtis
