shubham.pawar.external
226 Views, 3 Replies
ILogic for autoupdate Bearing Size and Bearing Generator
Hello all,
I have a query for autoupdating the bearing sizes through i logic.
being specifically, I have done a assembly of a shaft and bearing, but whenever i update the shaft diameter, i have to go for bearing generator to update the bearing size.
And adding one more thing that, i have to autoupdate other components based on the bearing size parameters, unfortunatly whenever I update the bearing, its component name also get changed and iLogic gives an error(component not found).
