A.Acheson
in reply to: Rossco44
So to make an in file edit without adjusting the styles you will need to override the style. You can do this with formatted text. I suggest to make a text box manually then adjust text /font as required then check out its formatted text.
The rule below will target the first text box on a sketch on a drawing.
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim
oSketch As DrawingSketch = oDrawDoc.ActiveSheet.Sketches(1)
Dim oTextBox As Inventor.TextBox = oSketch.TextBoxes(1)
sFormattedText = InputBox("","FormattedText",oTextBox.FormattedText)
You can also just put the text in as a general note and eliminate the need for a sketch which is a little unnecessary. See example here.
The same principle of formatted text will apply to that object also.
Regards
Alan
