j.romo
195 Views, 1 Reply
API VB.net Counting Parts in assembly
Hello Guys Im passing a old Ilogic rule to VB.net, the rule was courtesy of Mega Jerk.
The code is to Run in Assembly and count instaces of the same part and punt the instaces number in a parameter
to have the total count of parts in the drawing.
But Im running into an error, and havent figured out how to solve it.
any help would be appreciated
Here is The code
Public Class DATOS_FRM
    Private _inventor As Inventor.Application
    Public InventorApp As Inventor.Application = Marshal.GetActiveObject("Inventor.Application")
    Public assemblyDoc As AssemblyDocument = InventorApp.ActiveDocument
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        Dim ThisApplication As Inventor.Application = Marshal.GetActiveObject("Inventor.Application")
        Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
        Dim openDoc As Document
        Dim FNamePos As Long
        Dim docFName As String
        Dim assemblyDef As AssemblyComponentDefinition
        Dim partQty As ComponentOccurrencesEnumerator
        Dim docFile As PartDocument
        If oAsmDoc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
            Exit Sub
        Else
            'MsgBox("You must have a valid Assembly document open before using this code!", "File Type Mismatch!")
        End If
        For Each docFile In oAsmDoc.AllReferencedDocuments
                FNamePos = InStrRev(docFile.FullFileName, "\", -1)
                docFName = Mid(docFile.FullFileName, FNamePos + 1, Len(docFile.FullFileName) - FNamePos)
                If docFile.IsModifiable = True Then
                    oAsmDoc = openDoc
                    assemblyDef = oAsmDoc.ComponentDefinition
                    partQty = assemblyDef.Occurrences.AllReferencedOccurrences(docFile)
                    Try
                        If partQty.Count <> assemblyDef.iProperties.Value(docFName, "Project", "Authority") Then
                            assemblyDef.iProperties.Value(docFName, "Project", "Authority") = partQty.Count
                        End If
                    Catch
                    End Try
                End If
            Next
    End Sub
End Class
