Odalv
315 Views, 2 Replies
Inserting the same part multiple times with the same constraints
Hello!
I have a part that I need to insert into the assembly multiple times. Every time I insert this part, I need to make two constraints: the Z axis (Mate) and the XY plane (Flush).
Basically, I need to insert multiple occurrences of the same part, but with the same two constraints. The other constraints are different and I cannot use pattern.
I have found relatively simple code for constraining one instance of this part. But it will not work if I insert the same part multiple times because of the "occurence" number (marked with red) beside the part name.
Constraints.AddMate("Mate:1", "PartA:1", "Z Axis", "", "Z Axis",)
Constraints.AddFlush("Flush:1", "PartA:1", "XY Plane", "", "XY Plane")
I have tried to use only "" instead of part name, but that didn't work.
Would it be possible to use iLogic to automate this process?
