Darkforce_the_ilogic_guy
218 Views, 1 Reply
Dockbel windows how to I add buttom to run Ilogic code ?
I am using a VBA for today to run some Ilogic code . but my users would I a dockbel version.  I have fund this code that create a windows that work like I wanted it to... but how do I add buttom to it ? can I move my VBA form in to it so I do not have to create it form buttom up ?
the code I have is this
Dim oUserInterfaceMgr As UserInterfaceManager
        oUserInterfaceMgr = ThisApplication.UserInterfaceManager
        ' Create a new dockable window
        Dim oWindow As DockableWindow
        oWindow = oUserInterfaceMgr.DockableWindows.Add("SampleClientId4", "TestWindowInternalName4", "Test Window4")
        ' Get the hwnd of the dialog to be added as a child
        ' CHANGE THIS VALUE!
        Dim hwnd As Long
        hwnd = 4851096
        ' Add the dialog as a child to the dockable window
        oWindow.AddChild(hwnd)' Her I would Like To add a UserControl Or Userfrom!!!!!
        ' Don't allow docking to top and bottom
        oWindow.DisabledDockingStates = DockingStateEnum.kDockTop And DockingStateEnum.kDockBottom
        ' Make the window visible
        oWindow.Visible = True
 f as Windows.Forms.Form = New Windows.Forms.Form
                My_DockableWindow = ThisApplication.UserInterfaceManager.DockableWindows.Add(AddInClientID, AddInClientID, "NAMEX")
                My_DockableWindow.AddChild(f.Handle.ToInt64)
                My_DockableWindow.Width = 400
                My_DockableWindow.SetMinimumSize(400, 400)
With this:
You need to create a form first and add it to the Dockable Window.
Arthur Knoors
Arthur Knoors
Autodesk Affiliations:
