Dev_rim
in reply to: isocam
Hi there.
You have to create a Directory Info object using the path of the folder that contains files you want to delete. And look for all files inside of it "Test*.text"
If you want to look for all sub folders, You can use this:
Dim dinfo As New DirectoryInfo(YOUR_FOLDER_PATH)
For Each myFile In dinfo.GetFiles("Test*.txt", SearchOption.AllDirectories)
    File.Delete(myFile)
Next
If you want to check only the folder you entered, not the subfolders then you have to change "SearchOption.AllDirectories" to "SearchOption.TopDirectoryOnly".
I hope it will help.
Regards
Devrim
If my answer is solved your problem, please mark it as Solution
Freundliche Grüße / Kind Regards
