skseo
193 Views, 2 Replies
Can I check out the third party of the inventor dwg from the vault using ilogic?
Can I check out the 3rd party of the inventor dwg from the vault using ilogic?
3rd party document : autocad dwg, pdf
vault version : 2022 Professional
bradeneuropeArthur
in reply to: skseo
Could you tell me if the files are only Vault attachments or that they are Inventor Third-party files as linked items?
Could you otherwise share an file with this structure?
Arthur Knoors
Arthur Knoors
Autodesk Affiliations:
skseo
in reply to: bradeneuropeArthur
Thank you for your interest in my question.
Attach a file related to the question.
