WCrihfield
in reply to: steveh3
Hi @steveh3.  I am not sure.  What does the error message say?  Could you include what both tabs of the error message say when it pops-up?  There is usually a pretty good clue somewhere within the More Info tab, that would tell us what it was trying to do when the error was encountered, which will usually make it easier for us to pinpoint which line of code that is happening at.  Since you said it is working OK when ran manually, that makes me think there may be a timing issue involved.  Maybe the rule is triggered to run too early after the document is opened, and it maybe has not fully loaded all styles related stuff.  Just a thought.
Wesley Crihfield
(Not an Autodesk Employee)
