@WCrihfield wrote:
Hi @hayattangercekler2.  The most common problem I see when folks are drawing geometry entirely by code, that they then intend to extrude, is 'how' the geometry is drawn.  In order for the Coincident constraints to be inferred at the end points of the profile's sections, you need to either use end points or start points of existing geometry when drawing the next connecting piece of geometry, not just matching numerical locations.  Otherwise, you would need to go back and add those coincident constraints, in order for it to be recognized as a 'closed' profile.  Your 'line3' was done correctly, but not 'line2'.
@hayattangercekler2 ... I just looked at what @WCrihfield was saying about line 2 and realized that I should mention that I changed the way that line was done as well, but I didn't see that resolve the error. Maybe it was just a bad test on my end though?
I just checked again and it fails with the sketch edit lines if line 2 is done per your original example. You can test that on your end to see if the sketch edit lines are indeed needed, or if I fooled myself with those when I looked at the previously.
I hope this helps.
Curtis
