Hi @hayattangercekler2
I'm not entirely sure why that was not working, but adding a line to edit the sketch and then exit the sketch before and after the AddForSolid line seems to resolve the issue.
I hope this helps.
Curtis
    PartDocument oDoc = ThisDoc.Document;
    ComponentDefinition compDef;
    compDef = oDoc.ComponentDefinition;
    var _application = ThisApplication;
    PlanarSketch osketch = compDef.Sketches.Add(compDef.WorkPlanes(3));
    TransientGeometry tg = _application.TransientGeometry;
    Inventor.SketchLines lines = osketch.SketchLines;
    Inventor.SketchLine line1;
    Inventor.SketchLine line2;
    Inventor.SketchLine line3;
    line1 = lines.AddByTwoPoints(tg.CreatePoint2d(0, 0), tg.CreatePoint2d(0, 40));
    line2 = lines.AddByTwoPoints(line1.EndSketchPoint, tg.CreatePoint2d(40, 40));
    line3 = lines.AddByTwoPoints(line2.EndSketchPoint, line1.StartSketchPoint);
    osketch.Edit();
    Profile oProfile = osketch.Profiles.AddForSolid;
    osketch.ExitEdit();
    ExtrudeDefinition oExtrudeDef = compDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, PartFeatureOperationEnum.kJoinOperation);
    oExtrudeDef.SetDistanceExtent(4, PartFeatureExtentDirectionEnum.kSymmetricExtentDirection);
    ExtrudeFeature oExtrude = compDef.Features.ExtrudeFeatures.Add(oExtrudeDef);
Dim oDoc As PartDocument = ThisDoc.Document
Dim compDef As ComponentDefinition
Dim _application = ThisApplication
Dim osketch As PlanarSketch = compDef.Sketches.Add(compDef.WorkPlanes(3))
Dim tg As TransientGeometry = _application.TransientGeometry
Dim lines As Inventor.SketchLines = osketch.SketchLines
Dim line1 As Inventor.SketchLine
Dim line2 As Inventor.SketchLine
Dim line3 As Inventor.SketchLine
osketch.Edit
Dim oProfile As Profile = osketch.Profiles.AddForSolid
osketch.ExitEdit
Dim oExtrudeDef As ExtrudeDefinition = compDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, PartFeatureOperationEnum.kJoinOperation)
Dim oExtrude As ExtrudeFeature = compDef.Features.ExtrudeFeatures.Add(oExtrudeDef)
