hayattangercekler2
501 Views, 4 Replies
Triangle extrude production with inventor api c#
I want to make a triangular extrude + cut on an object with the inventor api. I use these codes for this, but "Profiles.AddForSolid();" I'm getting the "parameter incorrect" error in the function. How can I fix this error or is there a different extrude operation for the triangle?
error :
            PlanarSketch osketch = compDef.Sketches.Add(compDef.WorkPlanes[3]);
            TransientGeometry tg = _application.TransientGeometry;
            Inventor.SketchPoints points = osketch.SketchPoints;
            Inventor.SketchLines lines = osketch.SketchLines;
            Inventor.SketchLine line1;
            Inventor.SketchLine line2;
            Inventor.SketchLine line3;
            line1 = lines.AddByTwoPoints(tg.CreatePoint2d(0, 0), tg.CreatePoint2d(0, 40));
            line2 = lines.AddByTwoPoints(tg.CreatePoint2d(0, 40), tg.CreatePoint2d(40, 40));
            line3 = lines.AddByTwoPoints(line2.EndSketchPoint, line1.StartSketchPoint);
            Profile oProfile = osketch.Profiles.AddForSolid();
            ExtrudeDefinition oExtrudeDef = compDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, PartFeatureOperationEnum.kCutOperation);
            oExtrudeDef.SetDistanceExtent(4, PartFeatureExtentDirectionEnum.kSymmetricExtentDirection);
            ExtrudeFeature oExtrude = compDef.Features.ExtrudeFeatures.Add(oExtrudeDef);
Hi @hayattangercekler2.  The most common problem I see when folks are drawing geometry entirely by code, that they then intend to extrude, is 'how' the geometry is drawn.  In order for the Coincident constraints to be inferred at the end points of the profile's sections, you need to either use end points or start points of existing geometry when drawing the next connecting piece of geometry, not just matching numerical locations.  Otherwise, you would need to go back and add those coincident constraints, in order for it to be recognized as a 'closed' profile.  Your 'line3' was done correctly, but not 'line2'.
Wesley Crihfield
(Not an Autodesk Employee)
I'm not entirely sure why that was not working, but adding a line to edit the sketch and then exit the sketch before and after the AddForSolid line seems to resolve the issue.
I hope this helps.
Curtis
    PartDocument oDoc = ThisDoc.Document;
    ComponentDefinition compDef;
    compDef = oDoc.ComponentDefinition;
    var _application = ThisApplication;
    PlanarSketch osketch = compDef.Sketches.Add(compDef.WorkPlanes(3));
    line2 = lines.AddByTwoPoints(line1.EndSketchPoint, tg.CreatePoint2d(40, 40));
    osketch.Edit();
    Profile oProfile = osketch.Profiles.AddForSolid;
    osketch.ExitEdit();
    ExtrudeDefinition oExtrudeDef = compDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, PartFeatureOperationEnum.kJoinOperation);
Dim oDoc As PartDocument = ThisDoc.Document
Dim compDef As ComponentDefinition
Dim _application = ThisApplication
Dim osketch As PlanarSketch = compDef.Sketches.Add(compDef.WorkPlanes(3))
Dim tg As TransientGeometry = _application.TransientGeometry
Dim lines As Inventor.SketchLines = osketch.SketchLines
Dim line1 As Inventor.SketchLine
Dim line2 As Inventor.SketchLine
Dim line3 As Inventor.SketchLine
osketch.Edit
Dim oProfile As Profile = osketch.Profiles.AddForSolid
osketch.ExitEdit
Dim oExtrudeDef As ExtrudeDefinition = compDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, PartFeatureOperationEnum.kJoinOperation)
Dim oExtrude As ExtrudeFeature = compDef.Features.ExtrudeFeatures.Add(oExtrudeDef)
@hayattangercekler2 ... I just looked at what @WCrihfield was saying about line 2 and realized that I should mention that I changed the way that line was done as well, but I didn't see that resolve the error. Maybe it was just a bad test on my end though?
I just checked again and it fails with the sketch edit lines if line 2 is done per your original example. You can test that on your end to see if the sketch edit lines are indeed needed, or if I fooled myself with those when I looked at the previously.
I hope this helps.
Curtis
Thank you Curtis. Your solution worked successfully. :grinning_face_with_smiling_eyes:
