WCrihfield
in reply to: Shag_Bore
Hi @Shag_Bore.  Your code appears to be formatted incorrectly.  You only use the '&' symbol for piecing together sections of a String, not for consecutively setting values to numerical values.
This is how it should be formatted.
TEMP_EXTENTS_LENGTH = SheetMetal.FlatExtentsLength
TEMP_EXTENTS_WIDTH = SheetMetal.FlatExtentsWidth
x = TEMP_EXTENTS_LENGTH
y = TEMP_EXTENTS_WIDTH
If x > y Then
ElseIf x < y Then
	EXTENTS_LENGTH = SheetMetal.FlatExtentsWidth
	EXTENTS_WIDTH = SheetMetal.FlatExtentsLength
End If
Wesley Crihfield
(Not an Autodesk Employee)
