11-03-2022
08:08 AM
- Mute
- Permalink
- Report
11-03-2022
08:08 AM
Hi @wfajber
Thanks for your comprehensive explanations.
I figured it out, actually my problem was in defining suitable Object type for the "someProxy" variable.
I defined the object as EdgeProxy which matches the variable's type (see below).
Option Explicit
Sub PartSelection()
'Select drawing curve of the part
Dim oPick As DrawingCurveSegment
Set oPick = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Pick drawing curve")
'Get assembly occurrene which the selected DrawingCurveSegment belongs to
Dim curveSegment As DrawingCurveSegment
Set curveSegment = oPick
Dim parentCurve As DrawingCurve
Set parentCurve = curveSegment.Parent
Dim someProxy As EdgeProxy 'changed
Set someProxy = parentCurve.ModelGeometry
Dim partOcc As ComponentOccurrence
Set partOcc = someProxy.ContainingOccurrence
'Get AssemblyDocument referenced by DrawingView
Dim dView As drawingView 'needs to be checked
Set dView = parentCurve.Parent
Dim viewAsm As AssemblyDocument
Set viewAsm = dView.ReferencedDocumentDescriptor.ReferencedDocument
'Get all occurrences which has the same ComponentDefinition
Dim allInstancesOfPartOcc As ComponentOccurrencesEnumerator
Set allInstancesOfPartOcc = viewAsm.ComponentDefinition.Occurrences.AllLeafOccurrences(partOcc.Definition)
'Get all DrawingCurveSegments of each part instance
'and convert them to ObjectCollection
Dim occDrawingCurvesCollection As ObjectCollection
Set occDrawingCurvesCollection = ThisApplication.TransientObjects.CreateObjectCollection()
Dim occ As ComponentOccurrence
For Each occ In allInstancesOfPartOcc
Dim occDrawingCurves As DrawingCurvesEnumerator
Set occDrawingCurves = dView.DrawingCurves(occ)
Dim occDrawingCurve As DrawingCurve
For Each occDrawingCurve In occDrawingCurves
Dim occDrawingCurveSegment As DrawingCurveSegment
For Each occDrawingCurveSegment In occDrawingCurve.Segments
occDrawingCurvesCollection.Add (occDrawingCurveSegment)
Next
Next
Next
'Do something useful with occDrawingCurvesCollection
'Select all DrawingCurveSegments of the occ in the DrawingView
Dim drawingDoc As DrawingDocument
Set drawingDoc = dView.Parent.Parent
'drawingDoc.SelectSet.SelectMultiple (occDrawingCurvesCollection)
End Sub
To be honest, I have problem with defining object types for different purpose since there are many objects in the library. @wfajber are you able to let me know how I can attribute objects to the variables? Is there a pathway to learn it?
To be mentioned the code is not working yet and has some bugs, I need to fix it as well.
Waiting for your helpful reply
Sincerely yours
Mohammad
