11-02-2022
06:00 AM
- Mute
- Permalink
- Report
11-02-2022
06:00 AM
Your code with the addition of the unit conversion seems to be working for me.
It could be a style that's replacing the period with a comma for the decimal, see these links (Link1 , Link2 ).
Public Sub Test()
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveEditDocument
Dim oUOM As UnitsOfMeasure
Set oUOM = oDrawDoc.UnitsOfMeasure
Dim oSheet As Sheet
Set oSheet = oDrawDoc.ActiveSheet
Dim oDim As DrawingDimension
Dim oInspDimShape As InspectionDimensionShapeEnum
Dim oInspDimNumber As String
Dim oInspDimRate As String
Dim oInspDimTolUpper As Double
Dim oInspDimTolLower As Double
For Each oDim In oSheet.DrawingDimensions
If oDim.IsInspectionDimension Then
oDim.GetInspectionDimensionData oInspDimShape, oInspDimNumber, oInspDimRate
oInspDimTolUpper = oDim.Tolerance.Upper
oInspDimTolLower = oDim.Tolerance.Lower
oInspDimTolUpper = oUOM.ConvertUnits(oDim.Tolerance.Upper, UnitsTypeEnum.kDatabaseLengthUnits, UnitsTypeEnum.kInchLengthUnits)
oInspDimTolLower = oUOM.ConvertUnits(oDim.Tolerance.Lower, UnitsTypeEnum.kDatabaseLengthUnits, UnitsTypeEnum.kInchLengthUnits)
Debug.Print CStr(oInspDimShape)
Debug.Print oInspDimNumber
Debug.Print oInspDimRate
Debug.Print "Tol Type: " + CStr(oDim.Tolerance.ToleranceType)
Debug.Print "Tol Value: " + CStr(oDim.Text.Text)
Debug.Print "Tol Upper: " + CStr(oInspDimTolUpper)
Debug.Print "Tol Lower: " + CStr(oInspDimTolLower)
Debug.Print ""
End If
Next
End Sub
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
