37xitp4
443 Views, 4 Replies
Wrong tolerance value in VBA
I have Issue to get the value of upper & lower tolerance when using "Limit Linear Tolerance"
  1. It show different value of upper/lower tolerance, even if we put same tolerance on different dimension
  2. It show wrong value if we put the value of upper/lower tolerance same as the model value.
Public Sub InchInspectionTable()
'SET A REFERENCE TO THE ACTIVATE DRAWING
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
'SET REFERENCE TO THE ACTIVATE SHEET
    Dim oSheet As Sheet
    Set oSheet = oDrawDoc.ActiveSheet
'REMOVE EXISTING CUSTOM TABLE
    If oSheet.CustomTables.Count > 0 Then
    oSheet.CustomTables.Item(1).Delete
    End If
'CREATE CUSTOM TABLE
    Dim CustomTableTitle As String
    CustomTableTitle = "INSPECTION DIMENSIONS" 'Set the Table title
    Dim oTitles(1 To 4) As String 'set number of column
    oTitles(1) = "INSPECTION LABEL" 'Set the table header 1
    oTitles(2) = "DESIGNED DIMENSION" 'Set the table header 2
    oTitles(3) = "UPPER TOLERANCE" 'Set the table header 3
    oTitles(4) = "LOWER TOLERANCE" 'Set the table header 4
    Dim InsP As Point2d
    Set InsP = ThisApplication.TransientGeometry.CreatePoint2d(15, 15)
    oDrawDoc.StylesManager.ActiveStandardStyle.ActiveObjectDefaults.TableStyle.HeadingGap = 0.125
    oDrawDoc.StylesManager.ActiveStandardStyle.ActiveObjectDefaults.TableStyle.ColumnValueHorizontalJustification = kAlignTextCenter
    Dim oGenDimCount As Integer
    oGenDimCount = 0
    Dim oDim As DrawingDimension
    For Each oDim In oSheet.DrawingDimensions
        If oDim.IsInspectionDimension Then
            oGenDimCount = oGenDimCount + 1
        End If
    Next
    Debug.Print "Inspection Dims Count = " + CStr(oGenDimCount)
    Debug.Print "Drawing Dims Count = " + CStr(oSheet.DrawingDimensions.Count)
    Dim oCustomTable As CustomTable
    Set oInspDimTable = oSheet.CustomTables.Add(CustomTableTitle, InsP, 4, oGenDimCount, oTitles)
'SET THE VALUE OF THE TABLE
    Dim oInspDimShape As InspectionDimensionShapeEnum
    Dim oDesignedDimension As Variant
    Dim oAngularDesignedDimension As Variant
    Dim oInspDimNumber As String
    Dim oInspDimRate As String
    Dim i As Integer
    Dim oCellInspDimNum As Cell
    Dim oCellInspDim As Cell
    Dim oCellInspUpTol As Cell
    Dim oCellInspLowTol As Cell
    Dim oColor As Color
    Set oColor = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
    i = 1
        If oDim.IsInspectionDimension And oDim.Type = 117474560 Or oDim.IsInspectionDimension And oDim.Type = 117475072 Or oDim.IsInspectionDimension And oDim.Type = 117475328 Then 'Linier Dimension
            oDim.GetInspectionDimensionData oInspDimShape, oInspDimNumber, oInspDimRate
            oDesignedDimension = ThisApplication.UnitsOfMeasure.GetStringFromValue(oDim.ModelValue, 11272)
            Debug.Print oInspDimNumber
            Debug.Print oDesignedDimension
            Debug.Print "Tolerance type = " + CStr(oDim.Tolerance.ToleranceType)
            Debug.Print "Tolerance Upper = " + CStr(oDim.Tolerance.Upper)
            Debug.Print "Tolerance Lower = " + CStr(oDim.Tolerance.Lower)
            Debug.Print "Tolerance Precision = " + CStr(oDim.TolerancePrecision)
            Debug.Print ""
            Set oCellInspDimNum = oInspDimTable.Rows.Item(i).Item("INSPECTION LABEL")
            oCellInspDimNum.Value = oInspDimNumber
            Set oCellInspDim = oInspDimTable.Rows.Item(i).Item("DESIGNED DIMENSION")
            oCellInspDim.Value = oDesignedDimension
                Select Case oDim.Tolerance.ToleranceType
                    Case kDeviationTolerance 'Deviation Tolerance
                        Set oCellInspUpTol = oInspDimTable.Rows.Item(i).Item("UPPER TOLERANCE")
                        oCellInspUpTol.Value = oDim.Tolerance.Upper / 2.54
                        Set oCellInspLowTol = oInspDimTable.Rows.Item(i).Item("LOWER TOLERANCE")
                        oCellInspLowTol.Value = oDim.Tolerance.Lower / 2.54
                    Case kLimitLinearTolerance 'Limit Linear Tolerance
                    End Select
            i = i + 1
        End If
    Next
    oInspDimTable.Sort "INSPECTION LABEL", True
    Dim oRow As Row
    For Each oRow In oInspDimTable.Rows
        If oCellInspDimNum.Value <> oInspDimNumber Then
            oRow.Delete
        End If
    Next
End Sub
Tags (3)
dalton98
in reply to: 37xitp4
It looks like those values are in centimeters. If you wanted the the value to be exact you would set the tolerance to (1 * 2.54 = 2.54). Its a bit odd because you wouldn't use any values between 0-1 (* 2.54). Youll have to convert it to vba.
Dim oDrawingDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = oDrawingDoc.ActiveSheet
Dim oDim As DrawingDimension = oSheet.DrawingDimensions.Item(1)
'MessageBox.Show(oDim.ModelValue)
oDim.Tolerance.SetToLimits(ToleranceTypeEnum.kLimitLinearTolerance, 2 * 2.54, -0.4 * 2.54)
MessageBox.Show(oDim.Tolerance.Lower / 2.54)
'MessageBox.Show(Round(oDim.Tolerance.Upper, 3))
If oDim.Tolerance.Lower > 0 And oDim.Tolerance.Lower < 2.54
	oDim.Tolerance.SetToLimits(ToleranceTypeEnum.kLimitLinearTolerance, oDim.Tolerance.Upper, 1 * 2.54)
End If
37xitp4
in reply to: dalton98
Hi Dalton,
The code didn't work on my version (2019).
Even if it have default units in centimeter, it still show wrong value. I had put the deviation of tolerance from model value is 0.01", but it show different decimal value for each dimension :confused_face:.
tyler.warner
Your code with the addition of the unit conversion seems to be working for me.
It could be a style that's replacing the period with a comma for the decimal, see these links (Link1 , Link2 ).
Public Sub Test()
Set oDrawDoc = ThisApplication.ActiveEditDocument
Dim oUOM As UnitsOfMeasure
Set oUOM = oDrawDoc.UnitsOfMeasure
Dim oSheet As Sheet
Dim oInspDimTolUpper As Double
Dim oInspDimTolLower As Double
            oInspDimTolUpper = oDim.Tolerance.Upper
            oInspDimTolLower = oDim.Tolerance.Lower
            oInspDimTolUpper = oUOM.ConvertUnits(oDim.Tolerance.Upper, UnitsTypeEnum.kDatabaseLengthUnits, UnitsTypeEnum.kInchLengthUnits)
            oInspDimTolLower = oUOM.ConvertUnits(oDim.Tolerance.Lower, UnitsTypeEnum.kDatabaseLengthUnits, UnitsTypeEnum.kInchLengthUnits)
            Debug.Print CStr(oInspDimShape)
            Debug.Print oInspDimRate
            Debug.Print "Tol Type: " + CStr(oDim.Tolerance.ToleranceType)
            Debug.Print "Tol Value: " + CStr(oDim.Text.Text)
            Debug.Print "Tol Upper: " + CStr(oInspDimTolUpper)
            Debug.Print "Tol Lower: " + CStr(oInspDimTolLower)
            Debug.Print ""
        End If
    Next
End Sub
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
dalton98
It is odd when the upper tolerance value should be 0 it gives a very small negative value. You could account for this by adding an if statement:
If oCellInspUpTol.Value <= 1 And oCellInspUpTol.Value > -0.00001 Then
	oCellInspUpTol.Value = 0
End If
I couldn't re-create your problem where it gave a lower value as a value * E -2.
Like @tyler.warner it looks like like a styles problem. The dimension style wont update if you change the styles for the document, you either have to change the dimension with ilogic or delete and remake it.
