Thank you very much, you are the best. After looking at the codes again and changing their order and structure, I got the result I wanted. I had been working on it for a long time and this really pissed me off. There was no correct result from the answers of those who returned from the forum.
After all, I am sharing my correct working codes here.
            string openIam = "C:\\Users\\username\\Documents\\Assembly1.iam";
            string fullpath1 = "C:\\Users\\username\\Desktop\\sampleIam\\partiam.iam";
            string fullpath2 = "C:\\Servers\\partiam.iam";
            var documentOpen = _application.Documents.Open(openIam, true);
            if (_application.ActiveDocument.DocumentType != DocumentTypeEnum.kAssemblyDocumentObject) return;
            documentOpen.UnitsOfMeasure.LengthUnits = UnitsTypeEnum.kMillimeterLengthUnits;
            AssemblyDocument StartDoc = _application.ActiveDocument as AssemblyDocument  ;
            var oSketch = _application.ActiveEditObject;
            var oAsmCompDef = StartDoc.ComponentDefinition;
            TransientGeometry transientGeometry = _application.TransientGeometry;
            Matrix matrix3 = transientGeometry.CreateMatrix();
            matrix3.SetTranslation(transientGeometry.CreateVector(0, 0, 0));
            ComponentOccurrence oOcc3;
            oOcc3 = oAsmCompDef.Occurrences.Add(fullpath1, matrix3);
            PlanarSketch osketch = oAsmCompDef.Sketches.Add(oAsmCompDef.WorkPlanes[3]);
            TransientGeometry transientgeo = _application.TransientGeometry;
            SketchEntitiesEnumerator objects = osketch.SketchLines.AddAsTwoPointRectangle(transientgeo.CreatePoint2d(20, 0), transientgeo.CreatePoint2d(95, 10));
            SketchLine sketchLine = objects[1] as SketchLine;
            double oneLine = sketchLine.Length;
            double copyLine = oneLine / 2;
            Profile oProfile = osketch.Profiles.AddForSolid();
            ExtrudeDefinition extrudeDefinition = oAsmCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, PartFeatureOperationEnum.kCutOperation);
            extrudeDefinition.SetDistanceExtent(42, PartFeatureExtentDirectionEnum.kSymmetricExtentDirection);
            var oExtrude = oAsmCompDef.Features.ExtrudeFeatures.Add(extrudeDefinition);
            int ipt1Xinput = Convert.ToInt16(ipt1xkonum.Text);
            int ipt2Xinput = int.Parse(ipt2xkonum.Text);
            int ipt1X = ipt1Xinput + 75;
            int ipt2X = ipt2Xinput + 75;
            Matrix matrix1 = transientGeometry.CreateMatrix();
            matrix1.SetTranslation(transientGeometry.CreateVector(ipt1X , 0, 0));
            string ipt1file = openFileDialog1.FileName;
            ComponentOccurrence oOcc1;
            oOcc1 = oAsmCompDef.Occurrences.Add(ipt1file , matrix1);
            Matrix matrix2 = transientGeometry.CreateMatrix();
            matrix1.SetTranslation(transientGeometry.CreateVector(ipt2X , 0, 0));
            string ipt2file = openFileDialog2.FileName;
            ComponentOccurrence oOcc2;
            oOcc2 = oAsmCompDef.Occurrences.Add(ipt2file , matrix2);
            StartDoc.SaveAs(fullpath2, false);
