A.Acheson
in reply to: 2020mme013
Yes I believe there is differences between the export as pdf and ilogic save as using translator.
In the NameValueMap options you can try and adjust these options.
        'oOptions.Value("Remove_Line_Weights") = 0
        'oOptions.Value("Vector_Resolution") = 400
 In my previous testing I could not get the desired quality from the manual export. There doesn't seem to be much ability to control that process or the control is in multiple locations.  However I was able to adjust the ilogic method to work consistently.
Some other post discussing this topic
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/poor-pdf-quality-using-pdf-translato...
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Expor...
Regards
Alan
