WCrihfield
in reply to: C_Haines_ENG
OK.  I clearly do not fully understand what all you had in mind.  Maybe if you would explain the process you want this rule to do, in as much detail as possible, and maybe with bullet points, I (or others here) may be able to help you get it working the way you want it to work.
Wesley Crihfield
(Not an Autodesk Employee)
