10-27-2022
01:46 PM
- Mute
- Permalink
- Report
10-27-2022
01:46 PM
Hello, I have a few iLogic rules that I use to help automate the iProperties on the configurators. I use them across most of my configurators but every once in a while it errors out on specific subassemblies or components. In this case, if I suppress sub assembly VTHFAB4-MCI:1 , there is no error. So I tried to add an if statement just to skip that sub assembly but I am getting this error. I need help understanding why this would error out for specific components or sub assemblies. Also help understanding the error message for the conditional statement. Any help would be greatly appreciated.
Added conditional statement is on sub iPropPartsProject
'iPropertiesRule 'This rule will change the various iProperties of the Assembly, SubAssemblies and Piece parts. 'Requires - User parameters (Text): Designer, Project Sub main() iProp iPropColumn iPropPartsProject iPropPartsDate iPropPartsDesigner End Sub 'Changes Project of Assembly from the input on the form Sub iProp iProperties.Value("Project", "Project") = Project End Sub 'Changes custom Material iProperty for Assembly and Subassemblies, places catelog part number, places desciption based on material Sub iPropColumn Select Case PumpSize Case "4.0 in" iProperties.Value("ColumnPipe:1", "Project", "Stock Number") = "PP4SCH40C" iProperties.Value("ColumnPipe:1", "Project", "Description") = "PIPE, 4 in SCH40 - PP4SCH40C" iProperties.Value("ColumnPipe:1", "Project", "Part Number") = "4 IN COLUMN" Case "6.0 in" iProperties.Value("ColumnPipe:1", "Project", "Stock Number") = "PP6SCH40C" iProperties.Value("ColumnPipe:1", "Project", "Description") = "PIPE, 6 in SCH40 - PP6SCH40C" iProperties.Value("ColumnPipe:1", "Project", "Part Number") = "6 IN COLUMN" Case "8.0 in" iProperties.Value("ColumnPipe:1", "Project", "Stock Number") = "PP8SCH40C" iProperties.Value("ColumnPipe:1", "Project", "Description") = "PIPE, 8 in SCH40 - PP8SCH40C" iProperties.Value("ColumnPipe:1", "Project", "Part Number") = "8 IN COLUMN" End Select End Sub 'Goes through all parts & subassemblies and replaces the Project based on form inputs Sub iPropPartsProject Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition 'Iterate through all Of the occurrences Dim oOccurrence As ComponentOccurrence For Each oOccurrence In oAsmCompDef.Occurrences.AllReferencedOccurrences(oAsmCompDef) If oOccurrence = "VTHFAB4-MCI:1" Then Else 'create iprop with default Value iProperties.Value("Project", "Project") = Project 'write to component iprops iProperties.Value(oOccurrence.Name, "Project", "Project") = _ iProperties.Value("Project", "Project") MessageBox.Show(oOccurrence.Name, "Title") End If On Error Resume Next Next End Sub 'Pulls current date and goes though and updates date for every part, sub assembly and assembly Sub iPropPartsDate Dim strFileName As String strFileName = ThisDoc.Document.FullFileName Dim oFS As Object oFS = CreateObject("Scripting.FileSystemObject") Dim oDate1 As String 'Dim oDate2 As String oDate1 = oFS.GetFile(strFileName).DateLastModified 'oDate2 = oFS.GetFile(strFileName).DateCreated 'MessageBox.Show(oDate1 & " and " & oDate2) Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition 'Iterate through all Of the occurrences Dim oOccurrence As ComponentOccurrence For Each oOccurrence In oAsmCompDef.Occurrences.AllReferencedOccurrences(oAsmCompDef) 'create iprop with default Value iProperties.Value("Project", "Creation Date") = oDate1 'write to component iprops iProperties.Value(oOccurrence.Name, "Project", "Creation Date") = _ iProperties.Value("Project", "Creation Date") On Error Resume Next Next End Sub 'Pulls designer from form and goes though and updates designer for every part, sub assembly and assembly Sub iPropPartsDesigner Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition 'Iterate through all Of the occurrences Dim oOccurrence As ComponentOccurrence For Each oOccurrence In oAsmCompDef.Occurrences.AllReferencedOccurrences(oAsmCompDef) 'create iprop with default Value iProperties.Value("Project", "Designer") = Designer 'write to component iprops iProperties.Value(oOccurrence.Name, "Project", "Designer") = _ iProperties.Value("Project", "Designer") On Error Resume Next Next End Sub
