MjDeck
in reply to: shastu
It looks like it's not possible to modify the X position of the text for an existing hole note. You can set the Y value, but there are constraints on X. The hole note has a leader, but it is not available in the API. This is a problem on Inventor 2021, and probably on later versions as well.
The only thing I can recommend is to create the HoleThreadNote from scratch with the API. That should give you more control over text position than moving an existing note.
Mike Deck
Software Developer
Autodesk, Inc.
