10-24-2022
03:25 AM
- Mute
- Permalink
- Report
10-24-2022
03:25 AM
No, this did not work out as I had hoped, but you could apply some code to figure out the pieces and then make those pieces. I frequently use an Assembly file to figure out the size of part files I need and push parameter values to a part template that make up the parts. This is likely the workflow you'll end up with in the end.
This particular part I'm showing here we have to purchase as a full circle, and our production crews cut needed openings, so it finally worked out in the end to simply leave the entire ring as a single part number with notches cut into it the part. The BOM wasn't very efficient but it got the job done.
Good luck!
Autodesk Inventor Certified Professional
