10-17-2022
08:58 AM
- Mute
- Permalink
- Report
10-17-2022
08:58 AM
I'm working on an iLogic to look at the sheet metal flat pattern dimensions and select the correct part number. Right now I have it working correctly if the size is in between 2 numbers. The issue I'm running into is if say a 48 x 120 sheet is not in stock or unavailable but a 60 x 120 is in stock to select the larger sheet stock number.
I attached the excel file and the code below.
I also only want this to run on a sheet metal part. How would I go about doing that.
''Sheet Metal Stock Number
'Pulls flat pattern extents
Dim oLength As Double
Dim oWidth As Double
ex_Length = SheetMetal.FlatExtentsLength
ex_Width = SheetMetal.FlatExtentsWidth
'Checks flat pattern to see what length is longer and defines the longer side to be length
If ex_Length > ex_Width Then
oLength = ex_Length
oWidth = ex_Width
Else
oWidth = ex_Length
oLength = ex_Width
End If
'Define Excel File to Lookup
ExcelFile = "C:\CA Workspace\CAD Standards\CA Library A\iLogic Automation\CA - Sheetmetal Part Number Selection - Table.xlsx"
'Ignores any excel alerts
GoExcel.DisplayAlerts = False
'Message box warning for non stocked items
NonStockedNote = "This Item is not Stocked. Check with Purchasing on Availablity!"
Dim SheetMetalStyle As String
SheetMetalStyle = SheetMetal.GetActiveStyle
SheetMaterial = iProperties.Material
'IF the sheet is larger than 72 X 144 notifys user sheet is custom order
If (oWidth >72) AndAlso (oLength >144) Then
i = MessageBox.Show("Sheet is too large for Stocked material. Check with Purchasing if we can order custom sheet sizes", "Too Large of Sheet", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
SheetPartnumber = "Check With Purchasing if we can order a sheet this size."
End If
''Setting Width depending on sheet size
If (oWidth <= 48) AndAlso (oWidth >0) Then
oSetWidth = 48
Else If (oWidth <= 60) AndAlso (oWidth > 48.000001)
oSetWidth = 60
Else If (oWidth <=72) AndAlso (oWidth > 60.000001) Then
oSetWidth = 72
End If
''Setting Length depending on sheet size
If (oLength <= 120) AndAlso (oLength > 0)
oSetLength = 120
Else If (oLength <= 144) AndAlso (oLength > 120.000001)
oSetLength = 144
End If
'i = MessageBox.Show(oSetWidth & OSetLength, "Sheet Size", MessageBoxButtons.OK, MessageBoxIcon.None, MessageBoxDefaultButton.Button1)
Dim rowNum As Integer = GoExcel.FindRow(ExcelFile, "Stocked", "Sheet Metal Rule", "=", SheetMetalStyle, "Material", "=", iProperties.Material, "Sheet Width (Short Side)", "=", oSetWidth, "Sheet Length (Long Side)", "=", oSetLength)
'If no option is available then message box
If (rowNum >0) Then
If GoExcel.CurrentRowValue("Stocked") = "Yes" Then
SheetPartnumber = GoExcel.CurrentRowValue("Part Number")
question = MessageBox.Show("The Stock Number will be replaced with the "& SheetPartnumber &" are you sure you want to procceed", "Warning Stock Number Change", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
If question = vbNo Then
Else If question = vbYes Then
iProperties.Value("Project", "Stock Number") = SheetPartnumber
Return
End If
Else If GoExcel.CurrentRowValue("Stocked") = "No" Then
question = MessageBox.Show(NonStockedNote & "The Stock Number will be replaced with the "& SheetPartnumber &" are you sure you want to procceed", "Non Stocked Sheet", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
Return
End If
End If
Else If (rowNum <0) Then
i = MessageBox.Show("No Sheet Size Available. Check Purchasing for Part Number.", "No Sheet Size Available", MessageBoxButtons.OK, MessageBoxIcon.Warning, MessageBoxDefaultButton.Button1)
End If
