- Mute
- Permalink
- Report
I'm working on an iLogic to look at the sheet metal flat pattern dimensions and select the correct part number. Right now I have it working correctly if the size is in between 2 numbers. The issue I'm running into is if say a 48 x 120 sheet is not in stock or unavailable but a 60 x 120 is in stock to select the larger sheet stock number.
I attached the excel file and the code below.
I also only want this to run on a sheet metal part. How would I go about doing that.
''Sheet Metal Stock Number
'Pulls flat pattern extents
Dim oLength As Double
Dim oWidth As Double
ex_Length = SheetMetal.FlatExtentsLength
ex_Width = SheetMetal.FlatExtentsWidth
'Checks flat pattern to see what length is longer and defines the longer side to be length
If ex_Length > ex_Width Then
oLength = ex_Length
oWidth = ex_Width
Else
oWidth = ex_Length
oLength = ex_Width
End If
'Define Excel File to Lookup
ExcelFile = "C:\CA Workspace\CAD Standards\CA Library A\iLogic Automation\CA - Sheetmetal Part Number Selection - Table.xlsx"
'Ignores any excel alerts
GoExcel.DisplayAlerts = False
'Message box warning for non stocked items
NonStockedNote = "This Item is not Stocked. Check with Purchasing on Availablity!"
Dim SheetMetalStyle As String
SheetMetalStyle = SheetMetal.GetActiveStyle
SheetMaterial = iProperties.Material
'IF the sheet is larger than 72 X 144 notifys user sheet is custom order
If (oWidth >72) AndAlso (oLength >144) Then
i = MessageBox.Show("Sheet is too large for Stocked material. Check with Purchasing if we can order custom sheet sizes", "Too Large of Sheet", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
SheetPartnumber = "Check With Purchasing if we can order a sheet this size."
End If
''Setting Width depending on sheet size
If (oWidth <= 48) AndAlso (oWidth >0) Then
oSetWidth = 48
Else If (oWidth <= 60) AndAlso (oWidth > 48.000001)
oSetWidth = 60
Else If (oWidth <=72) AndAlso (oWidth > 60.000001) Then
oSetWidth = 72
End If
''Setting Length depending on sheet size
If (oLength <= 120) AndAlso (oLength > 0)
oSetLength = 120
Else If (oLength <= 144) AndAlso (oLength > 120.000001)
oSetLength = 144
End If
'i = MessageBox.Show(oSetWidth & OSetLength, "Sheet Size", MessageBoxButtons.OK, MessageBoxIcon.None, MessageBoxDefaultButton.Button1)
Dim rowNum As Integer = GoExcel.FindRow(ExcelFile, "Stocked", "Sheet Metal Rule", "=", SheetMetalStyle, "Material", "=", iProperties.Material, "Sheet Width (Short Side)", "=", oSetWidth, "Sheet Length (Long Side)", "=", oSetLength)
'If no option is available then message box
If (rowNum >0) Then
If GoExcel.CurrentRowValue("Stocked") = "Yes" Then
SheetPartnumber = GoExcel.CurrentRowValue("Part Number")
question = MessageBox.Show("The Stock Number will be replaced with the "& SheetPartnumber &" are you sure you want to procceed", "Warning Stock Number Change", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
If question = vbNo Then
Else If question = vbYes Then
iProperties.Value("Project", "Stock Number") = SheetPartnumber
Return
End If
Else If GoExcel.CurrentRowValue("Stocked") = "No" Then
question = MessageBox.Show(NonStockedNote & "The Stock Number will be replaced with the "& SheetPartnumber &" are you sure you want to procceed", "Non Stocked Sheet", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
Return
End If
End If
Else If (rowNum <0) Then
i = MessageBox.Show("No Sheet Size Available. Check Purchasing for Part Number.", "No Sheet Size Available", MessageBoxButtons.OK, MessageBoxIcon.Warning, MessageBoxDefaultButton.Button1)
End If
- Mute
- Permalink
- Report
Hi @KWarrenCA. As for how to set this rule up so that it will only run on a sheet metal part, I think the following bit of code should do that for you, if put right at the very start of your rule.
If ThisDoc.Document.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
MsgBox("This is not a Sheet Metal Part. Exiting rule.", vbCritical, "iLogic")
Exit Sub 'or Return
End If
I will revue the other request(s) and the Excel file next, if time/opportunity permits.
Wesley Crihfield
(Not an Autodesk Employee)
- Mute
- Permalink
- Report
I was able to rework this code to get it to work the way I wanted it to by looking for stocked items first if no stocked items were found it would search again for non stocked items.
'Checks to see if the file is sheet metal. If not it will return.
If oSubType = "Sheet Metal" Then
oLength = ex_Length
oWidth = ex_Width
Else
oWidth = ex_Length
oLength = ex_Width
End If
'Checks the sheet if it is larger than 72 X 144 notifies user sheet is custom order
End If
oSetWidth = 48
oSetWidth = 60
oSetWidth = 72
End If
If (oLength <= 120) AndAlso (oLength > 0) Then
oSetLength = 120
Else If (oLength <= 144) AndAlso (oLength > 120.000001)Then
oSetLength = 144
End If
'Used to verify it works on sheet size
Dim rowNum As Integer = GoExcel.FindRow(ExcelFile, "Stocked", "Sheet Metal Rule", "=", SheetMetalStyle, "Material", "=", iProperties.Material, "Sheet Width (Short Side)", ">=", oSetWidth, "Sheet Length (Long Side)", ">=", oSetLength, "Stocked", "=", "Yes")
'Checks if no option is available then displays message box to user
If (rowNum >0) Then
CostCode = GoExcel.CurrentRowValue("Cost Code")
question = MessageBox.Show("The Stock Number will be replaced with the "& SheetPartnumber &" are you sure you want to procceed?", "Warning Stock Number Change", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
Return
iProperties.Value("Project", "Cost Center") = CostCode
Return
End If
End If
Dim rowNum2 As Integer = GoExcel.FindRow(ExcelFile, "Stocked", "Sheet Metal Rule", "=", SheetMetalStyle, "Material", "=", iProperties.Material, "Sheet Width (Short Side)", ">=", oSetWidth, "Sheet Length (Long Side)", ">=", oSetLength, "Stocked", "=", "No")
If (rowNum2 >0)Then
question = MessageBox.Show(NonStockedNote & "The Stock Number will be replaced with the "& SheetPartnumber &" are you sure you want to procceed?", "Non Stocked Sheet", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
Return
Return
End If
Else If (rowNum2 <0) Then
End If
Else
Return
End If
