A.Acheson
in reply to: jingying_1213
In testing if the en-US folder is present and there is no no Weldment.iam file then this will default to a regular Assembly or the kAssemblyDocumentObject  because no subtype document is available. This also happens if the standard name "Weldment.iam" is not used. In your case it might be the case that the default name is not being used. You can test the path and if no path is shown then this will default to the kAssemblyDocumentObject.
MessageBox.Show(oTemplateFile, "Template Path")
Alternatively if you know the exact path of the weldment document you can load this directly.
Regards
Alan
