tyler.warner
in reply to: C_Haines_ENG
The dimension type from the command manager pick function should not matter whether there is no text, additional text or over-ridden text.
The issue you'll get with the above workflow is it will depend on how you created your dimensions. To get a "horizontal" or "vertical" dimension type, it will require two "points" to be picked. If two "lines" are picked, it will be the "aligned" dimension type.
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
